[OK]RC4: Quickslideshow doesn't stop in new fullscreen mode.
Locked
marsh
Post by marsh »
New Fullscreen mode used. When quick slide show gets to the end of the file list and <home> key is pressed, it looks like it restarts. It is not. Quickslideshow is not stopping when it reaches the end. This can be proven by hitting <pause> after Quickslideshow has reached the end. Then <home> key behaves normally. This does not occur in EDIT-fullscreen mode. Same thing occurs in RC3.
Dreamer
Post by Dreamer »
Works good here. There is some problem with a Pause key (not for all users) - try to use Space key only.
Dreamer
Re: RC4: Quickslideshow doesn't stop in new fullscreen mode.
marsh wrote:New Fullscreen mode used. When quick slide show gets to the end of the file list and <home> key is pressed, it looks like it restarts. It is not. Quickslideshow is not stopping when it reaches the end. This can be proven by hitting <pause> after Quickslideshow has reached the end. Then <home> key behaves normally. This does not occur in EDIT-fullscreen mode. Same thing occurs in RC3.
Yes, right the slide runs always...
marsh
Post by marsh »
Fixed.
Locked
