NConvert, RAW -> JPEG wrong color
morgantar
Post by morgantar »
Hi!
I'm using nconvert under OSX to convert my raw files to jpeg. I use this code:
/Users/dan/Desktop/nconvert -out jpeg /Users/dan/Pictures/Nikon/138\ -\ london\ 2011/DSC_3160.NEF
The output files have a strange color profile, images look more sepia. How i can solve it?
Thank you!
Re: NConvert, RAW -> JPEG wrong color
Is it possible to post your file?
rogerdahl
Post by rogerdahl »
I have this same problem, using NConvert 6.01.
When I open a RAW (NEF) file in XNView, the colors are very different from when I convert the same RAW file to JPG using NConvert and view the resulting JPG in XNView.
The command line I used was:
nconvert -out "jpeg" -q 90 -high_res -o DSC_3945.JPG DSC_3945.NEF
Here are two example files.
http://dl.dropbox.com/u/38272118/DSC_3945.JPG
http://dl.dropbox.com/u/38272118/DSC_3945.NEF
could you post the result that you have with XnView??
rogerdahl
Post by rogerdahl »
I'm using Windows 7.
Here's a screenshot of viewing the NEF in XnView:
http://www.dahlsys.com/upload/1937f170- ... c00008.png
And here's a screenshot of viewing the JPG:
http://www.dahlsys.com/upload/03f04aa1- ... c00008.png
The difference also shows in thumbnail view:
http://www.dahlsys.com/upload/414dac2e- ... c00008.png
And the good one is the nef viewed in XnView or the jpeg?
rogerdahl
Post by rogerdahl »
The NEF is the good one.
XnView displays NEF with the same colors as Photoshop does when converting with the NEF importer at all default settings (White Balance: As Shot).
http://rd.gnus.org/upload/DSC_3945.NEF% ... toshop.png
So the problem appears to be in the defaults, white balance or color profile that NConvert uses when it reads NEF.
Ok, please try
-raw_autobright -raw_autobalance
rogerdahl
Post by rogerdahl »
I really appreciate the help, and thank you for XnView -- it's awesome.
Using -raw_autobright -raw_autobalance makes a huge difference. The converted JPEG now looks almost exactly like the NEF (when displaying both in XnView). The JPEG is just very slightly more blue than the NEF. The difference on this image is so small that it doesn't matter to me, but the "auto" settings seem to indicate that the brightness and balance is no longer deterministic, but based on an analysis of the photo? If so, is there a switch that I can use to get a "standard' conversion that matches what XnView does? (Assuming that XnView does not do the equivalent of -raw_autobright -raw_autobalance).
