Is there any keyboard shortcut that allows me to go to a folder by entering the path directly (i.e. by typing or copy-pasting the path). It looks like Ctrl+O only works for files, and not folders.
Am I missing anything?
Thanks
Keyboard shortcut to open path ?
Re: Keyboard shortcut to open path ?
In the folder edit box?
rlio77
Right, but is there a keyboard shortcut to it? (e.g. in Freecommander Alt+G = Go to folder, which allows you to type or paste the address directly).
Thanks
Thanks
no, sorry
lian
I use Find and Run Robot for this kind of stuff.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
