Round edges on adding a border
Asmo
Post by Asmo »
It would be great if it was possible to add round edges when adding a border. See for example this image I have on my website:
http://www.peatfreak.com/albums/Lucas%2 ... ewerkt.JPG
In this case, the green on the corners is the background color so it will blend in on my website, but if the edges could be transparent (png) that would be even better.
Thanks,
Jeroen
Asmo
Re: Round edges on adding a border
Post by Asmo »
BTW, I use bordermaker (.nl) for it now. Maybe a program that can inspire you for a new feature.
Love XnConvert! Looking forward to future versions.
ok :)
Asmo
Post by Asmo »
Thank you so much!
Asmo
Post by Asmo »
Thank you again for this feature!
I have one small (I hope) request. The anti-aliasing also anti-aliases the straight vertical and horizontal lines. If I add a 1px line, for example black, it means this line will be a bit fuzzy and grey-ish instead of black.
Is it possible to select a anti-aliasing method that would leave straight lines intact?
Thank you so much,
Jeroen
ok, i'll add
