When I use batch processing (f. g. resize) on pictures containing ICC profiles and have the pictures saved in JPEG or TIFF format, everything works perfectly: The processed pictures are left in the original colors and have the correct profile embedded.
Unfortunately this is not true when I save single pictures directly via "Save" or "Save As...".
Bug 1:
When I open a picture in XnView and save it via "File > Save As..." in JPEG format, XnView does embedd the correct profile, but leaves the colors in the monitor color space.
Bug 2:
When I open a picture in XnView and save it via "File > Save" or "File > Save As..." in TIFF format, XnView leaves the colors in the monitor color space and embedds the monitor profile.
Bugs in color management when saving
Re: Bugs in color management when saving
Yes, save/saveas convert the picture with ICC profile, so profile can't be kept...
beiti
But this is wrong. Can't you change it in one of the next versions?xnview wrote:Yes, save/saveas convert the picture with ICC profile, so profile can't be kept...
Currently it's not possible, the picture loaded is in sRGBbeiti wrote:But this is wrong. Can't you change it in one of the next versions?xnview wrote:Yes, save/saveas convert the picture with ICC profile, so profile can't be kept...
Slider2k
As of v.2.39 color management is still incompatible with image editing/saving.
Problem:
If color management is enabled and ICC profile is selected an image's color values are translated into that ICC profile's color space (usually monitor's) upon opening and displaying. As if the selected ICC profile is the "working space". If an image is saved the translated color values are saved "as is" in an untagged RGB color space. This leads to incorrect display of colors upon viewing the saved image in color managed apps, as untagged RGB images are assumed to be in sRGB color space by default. But even when viewing this image with correct ICC profile manually assigned, the noise introduced by quantization error due to forced color space conversions becomes apparent.
Solution:
An image's original color space should be kept intact and all work should be done in that color space (original RGB values) without any color conversions, and subsequently be saved in that color space. The color management function should only be used for on-the-fly color space conversion for displaying purposes only.
Problem:
Solution:
