picture resolution into a filename
Bobus
Post by Bobus »
Hi guys,
Finally got tired of resizing my pictures manually through XnView GUI and decided to do it with nConvert :idea: . Then possibly will add it as a button for Total Commander toolbar. But that's later, now, a question, is it possible to add picture resolution to the resulting filename? E.g. to resize picture_big.jpg to picture_small_1024x653.jpg?
Preferably with nconvert, but other options considered, except for manual renaming : )
Cheers,
Bobus :mrgreen:
marsh
Re: picture resolution into a filename
Post by marsh »
XnView's batch rename function can add resolution to filename by using file template. This way you would have current resolution.
Ex.
<filename>_<Width>_<Height>_####
XnConvert can also add resolution (taken from original) to output filename .
Bobus
Post by Bobus »
marsh, thank you for a reply. Could you please explain how to use XnConvert to add resulting file resolution/pix dimensions to its filename? I did searched XnConvert help, but nothing close came up by 'resolution' or 'dimensions' keywords.
marsh
Post by marsh »
Using resulting resolution I was unable to discover.
you have {DPI}
Bobus
Post by Bobus »
marsh, okay, what about the original's pixel dimensions? May be it is possible to run nConvert twice to rename the file after resizing?
xnview, would it be possible to kindly add such a feature? As I understand it, DPI is for completely different purpose.
Imesh
Post by Imesh »
yes DPI is for another purpose...
I'm an Undergraduate and I love to learn
