some of my original photos are vertical and others are horizontal,
how can they to be all horizontal after XnC MP batch converted ? I don't need them keep the orientation in the metadata.
how to delete original orientation?
lostcpu
Re: how to delete original orientation?
You would like to change the EXIF orientation flag?
lostcpu
for example. the batch I want to convert, some are 800*600 some are 600*800 when browsing.
now I want to convert them all to 640*480 without exif info or any metadata.
and the oriantation of 600*800 will be as 800*600.
like | will be ---
like | will be ---
So if i understand you correctly:
800x600=>640x480
600x800=>rotate=>640x480
800x600=>640x480
lostcpu
Here is the different between XnView 1.98 convert and XnC MP,
there are 2 photos
orginal view by XnV or XnV MP.
800*600
800*600
orginal view by thumbnail in total commander
800*600
600*800
XnView 1.98 convert way (I don't know whether it's determined by a default setting that can't be changed or any setting that set by myself)
after batch convert:
800*600
800*600
XnC MP
800*600
600*800
What I mean is, how can I control the result as 1.98 way or Xnc MP way.
sometimes I need it act like 1.98way, sometimes I need it act like XnC MP way.
Please consider there are hundreds of photos with orientation like these, I don't want to get the result that orientation of 30% photos is not what I want and then I have to rotate one by one.
there are 2 photos
800*600
800*600
800*600
600*800
800*600
800*600
XnC MP
800*600
600*800
Strange, could you send me 2 picture files, and the XnView & XnConvert script, please?
lostcpu
OK, I'll send some sample to your email later.
