XnConvert 1.02 PCD conversion
LDMartin1959
I guess I am missing something here. I have .PCD files which I think may have multiple levels of image quality imbedded. Is there a way to use XnConvert to determine which resolution levels are in a .PCD file and then have it extract specific (or the highest) resolutions available?
Re: XnConvert 1.02 PCD conversion
Are you on windows?
