Shortcut to plugin changed after update
lian
Post by lian »
Hello, the plugin to zip files does not work anymore with XNV 1.98 ? :x
Sorry, just the shortcut I created for the plugin on the bar that does not work anymore. The shortcut to Ftp plugin works so I have to take a look at this.
Sorry again, the shortcut was changed (?) after installation. I just had to correct this. First time it occurs...
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Shortcut to plugin changed after update
you means toolbar icon?
lian
Post by lian »
Yes, sorry (bad english :-))
lian wrote:Yes, sorry (bad english :-))
Strange, and now all works?
lian
Post by lian »
Yes, everything works fine. Just this icon not pointing anymore to the good exension.
