Pressing escape does not close XnView or the current tab.
malcolm341
Seems like there is bug, hitting escape does not work for me to close a tab or the XnView window. Even with "Pressing ESC once quites XnView" set to "Always." I'm on version 1.98 (May 9 2011) Hitting esc worked when I first installed it this morning but doesn't work anymore? Oh wait, I just found a work around. Pressing alt + esc closes XnView and leaves all the tabs open. Pressing Ctrl + w will close each tab and close XnView when there is only one tab open. Has the esc functionality changed?
Re: Pressing escape does not close XnView or the current tab
no, it works for me
