plugins sdk bug report
azsd
Post by azsd »
typedef struct {
  unsigned char red[256];
  unsigned char green[256];
  unsigned char blue[256];
} GFP_COLORMAP;
in sdk sample get from win32 download page,the struct [3][256](r,r,r,r...g,g,g,g....b,b,b,b) must be [256][3](rgb,rgb,rgb,rgb...),or the color pattle of image will be strage.
I changed it to:
tagGFP_COLORMAPItem = packed record
  R:Byte;
  G:Byte;
  B:Byte;
end;
tagGFP_COLORMAP = packed record
  Colors:array[0..255] of tagGFP_COLORMAPItem;
end;
and worked fine.
I used a 4bit gray muilty page image format on pda,and use lcd like color pattle in plugins codes, and found this bug.
PS: Is there more detailed sdk codes avalible for download?
I can't use the muility page/layer feather,can't display an option page like others plugins, and can't make the image animated.
Re: plugins sdk bug report
azsd wrote:
typedef struct {
} GFP_COLORMAP;
in sdk sample get from win32 download page,the struct [3][256](r,r,r,r...g,g,g,g....b,b,b,b) must be [256][3](rgb,rgb,rgb,rgb...),or the color pattle of image will be strage.[/code]
Strange, i'll check
Currently not available with SDK
