0. Open a .png file
1. Open «Rotate custom» dialog
2. Enter non-zero value for an angle
3. Background of a picture is transparent. You cannot change this behaviour. It does not matter what color is selected as a background color.
Could you please add "transparency" checkbox and allow creating non-transparent images?
Luckily, "Remove alpha channel" works after that.
1.98: When rotating a png, background is always transparent
Zverik
Re: 1.98: When rotating a png, background is always transpar
your png file has an alpha before?
