http://xnconvert.com
Peter2
Post by Peter2 »
Error: Couldn't open config file "awstats.xnconvert.com.conf" nor "awstats.conf" after searching in path "/home/stats/cgi-bin,/etc/awstats,/usr/local/etc/awstats,/etc,/etc/opt/awstats": No such file or directory
- Did you use the correct URL ?
Example: http://localhost/awstats/awstats.pl?config=mysite
Example: http://127.0.0.1/cgi-bin/awstats.pl?config=mysite
- Did you create your config file 'awstats.xnconvert.com.conf' ?
If not, you can run "awstats_configure.pl" from command line, or create it manually.
Check config file, permissions and AWStats documentation (in 'docs' directory).
Peter
Re: http://xnconvert.com
Seems to be fixed.
