After my problem (http://newsgroup.xnview.com/viewtopic.p ... 056#p94056), I think that the IPTC editor is missing the following mode:
In multiselection mode, instead of displaying the first image, the editor should display a multi selection mode, with already all fields cleared (like Clear all on the first image). The best would be to display the common value, but I think that it will a lot more complex to do it.
And the for keyword page, pressing Enter key should do exactly the same thing as pressing the Add button (it isn't the case now after a Clear all).
This feature request is also valid for XnviewMP.
Common edition of IPTC for muliselection
Vapavite
Re: Common edition of IPTC for muliselection
Sorry, but Add or Enter, ok !!!And the for keyword page, pressing Enter key should do exactly the same thing as pressing the Add button (it isn't the case now after a Clear all).
Vapavite @+
PBY
Sorry, but I retested with a freshly installed 1.98 version, Enter key and Add button have definitely not the same handling. See the screenshots:
1 - Opening of IPTC editor: 2- Clear all 3a - add a new keyword by pressing Enter key
PBY
PBY
3b - add a new keyword by clicking Add button
PBY
ENTER activate the Write buttonPBY wrote:Sorry, but I retested with a freshly installed 1.98 version, Enter key and Add button have definitely not the same handling. See the screenshots:
PBY
only when nothing else has the focus.xnview wrote:ENTER activate the Write button
After writing a keyword in the textbox, the textbox still have the focus, and pressing enter at this moment will add the keyword to the list, but in a strange way.
PBY
