Hi, gotta say loving the XNView series.
Now to the problem, I selected multiple folders in the view pane (Displays the thumbnails), and selected move to....
In other programs it will just move the selected folders to the new path folder, but instead it moved the pictures from each folder, into the specified folder.
This lost the folder structure, and massed the pictures into the new folder.
I hope that isn`t the intended operation.
Keep up the good work!
Edit - I also tried moving the files back using move to and it came up copying files, so now I have 2 sets of images!
Edit - I`m using windows 7 64 bit!
Move to [Folders]
Zheitk
Re: Move to [Folders]
I have a related problem. When I drag the images to another folder (normal windows behavior) the program only makes copies in the other directory, instead of moving them.
Also, it would be good to have an animation (a shadow) to know that you are moving a group of pics
I can't reproduce, are you able to reproduce this problem?dragonsblade71uk wrote: In other programs it will just move the selected folders to the new path folder, but instead it moved the pictures from each folder, into the specified folder.
Do you press SHIFT?I have a related problem. When I drag the images to another folder (normal windows behavior) the program only makes copies in the other directory, instead of moving them.
Zheitk
Etoo, Yea, for select several pics, I always do it that way o_oDo you press SHIFT?
and not moved?Zheitk wrote:Etoo, Yea, for select several pics, I always do it that way o_oDo you press SHIFT?
lian
I have the problem with the MP version, not the "classic version".
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
'Move to' doesn't work? or drag&drop of folder in thumbnail view?lian wrote:I have the problem with the MP version, not the "classic version".
Zheitk
I now realize that you need to press SHIFT while dragging the images. That is strange behavior for me. Can I change this in the preferences?and not moved?
On the other hand, for pure aesthetics, this is the shadow effect I like in XP (just a suggestion)
Please check XnViewMP 0.38
