Dear xnview developers,
I suffer from xnview crash when I rotate JPEG image left/right (using Ctrl-Shift-L or Ctrl-Shift-R) and then clicking on another image while rotation is being performed. The bug not so difficult to reproduce, but I have no exact steps.
I have generated a mini crash dump – perhaps this will help to narrow the problem.
Additional info:
* xnview v1.98
* Windows7 x64
Crash on image rotation (?)
Re: Crash on image rotation (?)
During rotation, i can't click on another thumb
dma_k
Yes, that is true: when rotation is in progress, the program does not respond to UI events.xnview wrote:During rotation, i can't click on another thumb
As I mentioned I have no reliable steps. Perhaps it is selection of image, perhaps it is view scrolling – I couldn't define the exact steps for myself as well. Sometimes I cannot catch the bug for days, sometimes I am able to crash xnview several times a day. I usually work with JPEGs created by my camera, so it does not seem to depend on the data, but rather on amount of images for rotation.
I hope that minidump will help you. Does it show the detailed stacktrace? Perhaps I can generate a stracktrace myself, if I have a symbols table (.pdb).
No sorry the minidump can't help me. It would be great if you can find a way to reproduce it...dma_k wrote:I hope that minidump will help you. Does it show the detailed stacktrace? Perhaps I can generate a stracktrace myself, if I have a symbols table (.pdb).
rpla
Hi folks,
After two years as happy user of Ubuntu (9.10 AMD64) I did migrate to Debian.
I update too XnView from 0.26 to 0.35 release.
Some fine tuning at Gnome menu command, and Xnview run without problems ...until I atempt to rotate an image, then it crash and the program window has disappeared from my screen.
I'm going to execute program from terminal to get a error message,
$ ./xnview.sh
and repeat the crash action, getting those log at terminal (final action):
###### LOAD BITMAP </home/user1/docs/img/img_5.jpg> 4
2 4 8 8
2 4 8
## MyView::onLoaded </home/user1/docs/img/img_5.jpg> </home/user1/docs/img/img_5.jpg> </home/user1/docs/img/img_5.jpg> (0)
## MyView::onLoaded ok
Marker : e0 14
Marker : e1 3966
Marker : ed 10828
Marker : e1 4862
Marker : e2 3158
Marker : ee 12
## BitmapLoadThread :: load 600 450
### resetViewport (1fc0aa0) ==> 413 240 (320 240) 0 0
Create Tree : File
Create Tree : Image
Create Tree : Color Profile
## MyView::onLoaded </home/user1/docs/img/img_5.jpg> </home/user1/docs/img/img_5.jpg> </home/user1/docs/img/img_5.jpg> (1)
### ThumbLoaderThread :: stop()
Segmentation fault
After that I guess to do some other operations, as resize, copy, rename files. I can rotate other format files as .tif or .jp2, convert format from .tif to .jpg, all them OK, but when I'm going to rotate .jpg file, XnView, fall down.
For me is very easy to reproduce the crash: it even occur when I attempt to rotate a jpg image, I did does that with the tools button.
After the button is pushed, a dialgog about the possible lose of quality is showed... as you can see :
With only a diference: the cursor is not the pointer as in the image, but the 'clock' to 'wait'...
When click on 'OK' button, XnView crash.
I hope you found those information useful to catch the bug
à bientôt,
Roberto Pla
$ ./xnview.sh
2 4 8 8
2 4 8
Marker : e0 14
Marker : e1 3966
Marker : ed 10828
Marker : e1 4862
Marker : e2 3158
Marker : ee 12
Create Tree : File
Create Tree : Image
Segmentation fault
à bientôt,
Roberto Pla
