Portable version of MP?
ghost zero
Post by ghost zero »
Is there a portable version of MP? So we can test it without installing?
Zheitk
Re: Portable version of MP?
Post by Zheitk »
Man, MP is portable, it comes in a zip file, it saves the conf files in User\Program data\XnViewMP, but there is an option to save it in the program folder
Tools > Settings > Integration > Save settings
budz45
Post by budz45 »
Zheitk wrote:Man, MP is portable, it comes in a zip file, it saves the conf files in User\Program data\XnViewMP, but there is an option to save it in the program folder
It is already portable in that manner, yes, but it still currently saves the settings files elsewhere and not within the program's folder.
I have already started a topic for XnConvert for Pierre to make a Portable Apps folder arrangement, similar to an app from PortableApps.com after it's been installed:
Portable apps folder arrangement (Please)
vommie
Post by vommie »
budz45 wrote:It is already portable in that manner, yes, but it still currently saves the settings files elsewhere and not within the program's folder.
I have to take issue with that - XnViewMP stores all the config files in the root dir of XnViewMP, if you use the settings like in this screenshot:
I can't find files of XnView outside the programs root dir.
budz45 wrote:Portable apps folder arrangement
Oh, please, no. I think PortableApps and it's folder arrangement sucks for XnViewMP, as it's native portable feature is much more dynamic and clear.
