This image:
http://wallbase.cc/wallpaper/342930
When opened in XnView with the EXIF User Comment tag showing (<User Comment>), displays nothing in that field. Opening the same image in another viewer (IrfanView) with the same tag showing, shows this text:
gd-jpeg v1.0 (using IJG JPEG v62), quality = 80
Which program is correct?
Thanks.
EXIF User Comment
ehathgepiurhe
Re: EXIF User Comment
Thanks Pierre - hope to see a fix in a later version
Regards.
Regards.
ehathgepiurhe
Confirmed fixed in v1.98.1. Thanks Pierre.
Regards.
CM
Regards.
CM
