I cropped the same jpeg file with both XnView and XnViewMP.
Afterwards the thumbnails of the ones cropped in MP showed the picture of the original jpeg and with wrong orientation (in both XnView and MP). Additionally, the ones cropped in MP have sizes one bigger than and one almost as big as the original jpeg. The one cropped with XnView has a size half as big as the original jpeg.
This happens no matter whether "rebuild embedded thumbnail" in the format settings is activated or not.
XnView 1.98
XnViewMP 0.38
Windows XP SP3
[MP0.38win] wrong thumbnail and file size after crop
bege
marsh
Re: [MP0.38win] wrong thumbnail and file size after crop
Both programs have same crop result for me. These options might be related (for v.0.35 at least)
1. '[x]Rotate image based on exif orientation'. v.1.98 cropping and saving will reset from Exif orientation (right-top) to (top-left).
2. Jpeg quality (a level higher than what original used can create bigger file).
Default in MP xnview.ini:
[Save]
JPEGQuality=80
Default in v.1.98:
[Save]
JpegQuality=80
[Save]
JPEGQuality=80
Default in v.1.98:
[Save]
JpegQuality=80
bege
Hi marsh,
thanks for your answer.
So I still don't understand what makes the difference in my case.
Did you crop a file of which the thumbnail is rotated to upright format?
This option is activated in both programs.marsh wrote:Both programs have same crop result for me. These options might be related (for v.0.35 at least)
I have the settings in both programs equal (quality best, use estimated quality (when possible)).marsh wrote:2. Jpeg quality (a level higher than what original used can create bigger file).
[Save]
JPEGQuality=80
Default in v.1.98:
[Save]
JpegQuality=80
marsh
Yes I changed orientation first. Cropped 80% of duplicate jpeg and had 7.6K files at end.bege wrote: I have the settings in both programs equal (quality best, use estimated quality (when possible)).
I have not tried estimated quality.
v.1.98:
[Save]
UseOrgJPEGQuality=0
MP:
[Save]
useOriginalJPEGQuality=false
Could you send me the picture file used?
bege
I sent it to the webmaster e-mail address.xnview wrote:Could you send me the picture file used?
Regards
ok, the 'rebuild thumbnail' is not used...
bege
... and will be fixed in the next version?xnview wrote:ok, the 'rebuild thumbnail' is not used...
Thank you very much.
Regards
yesbege wrote:... and will be fixed in the next version?xnview wrote:ok, the 'rebuild thumbnail' is not used...
