0.35 Linux: segfault on ubuntu 11.04
rmtk
Post by rmtk »
Just updated ubuntu from 10.10 to 11.04, but xnviewmp failed to start.
I use 32bit version on my 64bit system, since 64bit xnviewmp is buggy: http://newsgroup.xnview.com/viewtopic.php?f=62&t=22347
Look forward for help.
treminal log:
(<unknown>:3004): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64
(<unknown>:3004): Gtk-WARNING **: Loading IM context type 'ibus' failed
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1278 725
w.init
XNVIEW SIZE 1278 725
########### BrowserWindow :: BrowserWindow
MENU install : 8bce318
### ThumbLoaderThread :: stop()
QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
BrowserWindow :: updateMenu()
########### BrowserWindow :: restoreState (1278 725)
XNVIEW resize : 1278 725
## MyTabWidget :: resizeEvent : 1278 725
## RESIZE: 981 558
### MyBitmapView (8c7b570) :: resizeEvent 389 157
### MyBitmapView (8c7b570) :: resizeEvent 507 157
## RESIZE: 1278 692
### BrowserWindow :: onStart
BrowserWindow :: onStart 2
setPathname </home/rm/ALL/Documents/Pictures/??/>
## OPEN FOLDER
## OPEN FOLDER ok
## updateLabels
## updateLabels ok
### ThumbLoaderThread :: setFileList()
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 8c0d9d0
######ThumbLoaderThread :: forever : 8c0d9d0
### ThumbLoaderThread :: setFileList() ok
######ThumbLoaderThread :: start : 24
ThumbLoaderThread => 0 (-1 -1)
DB (7285) : 4096 4096
ThumbLoaderThread - LOADED from DB (7285)
ThumbLoaderThread - loadThumb from DB (7285 - BNU)
QFileSystemWatcher: failed to add paths: /home/rm/ALL/Documents/Pictures/照片/
ThumbLoaderThread => 1 (-1 -1)
DB (8805) : 4096 4096
ThumbLoaderThread - LOADED from DB (8805)
ThumbLoaderThread - loadThumb from DB (8805 - ECNU)
ThumbLoaderThread => 2 (-1 -1)
DB (1) : 4096 4096
ThumbLoaderThread - LOADED from DB (1)
ThumbLoaderThread - loadThumb from DB (1 - SJTU)
ThumbLoaderThread => 3 (-1 -1)
DB (2) : 12288 12288
ThumbLoaderThread - LOADED from DB (2)
ThumbLoaderThread - loadThumb from DB (2 - ???)
ThumbLoaderThread => 4 (-1 -1)
DB (3) : 12288 12288
ThumbLoaderThread - LOADED from DB (3)
ThumbLoaderThread - loadThumb from DB (3 - ???)
ThumbLoaderThread => 5 (-1 -1)
DB (12255) : 12288 12288
ThumbLoaderThread - LOADED from DB (12255)
ThumbLoaderThread - loadThumb from DB (12255 - ???)
ThumbLoaderThread => 6 (-1 -1)
DB (15889) : 4096 4096
ThumbLoaderThread - LOADED from DB (15889)
ThumbLoaderThread - loadThumb from DB (15889 - ??)
ThumbLoaderThread => 7 (-1 -1)
DB (4) : 4096 4096
ThumbLoaderThread - LOADED from DB (4)
ThumbLoaderThread - loadThumb from DB (4 - ??)
ThumbLoaderThread => 8 (-1 -1)
DB (12256) : 12288 12288
ThumbLoaderThread - LOADED from DB (12256)
ThumbLoaderThread - loadThumb from DB (12256 - ??)
MyDirModelThread :: run
ThumbLoaderThread => 9 (-1 -1)
DB (7101) : 4096 4096
ThumbLoaderThread - LOADED from DB (7101)
ThumbLoaderThread - loadThumb from DB (7101 - ??)
ThumbLoaderThread => 10 (-1 -1)
DB (13347) : 4096 4096
ThumbLoaderThread - LOADED from DB (13347)
ThumbLoaderThread - loadThumb from DB (13347 - ??)
ThumbLoaderThread => 11 (-1 -1)
DB (13348) : 20480 20480
ThumbLoaderThread - LOADED from DB (13348)
ThumbLoaderThread - loadThumb from DB (13348 - ??)
ThumbLoaderThread => 12 (-1 -1)
DB (5) : 4096 4096
ThumbLoaderThread - LOADED from DB (5)
ThumbLoaderThread - loadThumb from DB (5 - ???)
ThumbLoaderThread => 13 (-1 -1)
DB (6) : 20480 20480
ThumbLoaderThread - LOADED from DB (6)
ThumbLoaderThread - loadThumb from DB (6 - ?????)
ThumbLoaderThread => 14 (-1 -1)
DB (7) : 4096 4096
ThumbLoaderThread - LOADED from DB (7)
ThumbLoaderThread - loadThumb from DB (7 - ????)
ThumbLoaderThread => 15 (-1 -1)
DB (8) : 4096 4096
ThumbLoaderThread - LOADED from DB (8)
ThumbLoaderThread - loadThumb from DB (8 - ????)
ThumbLoaderThread => 16 (-1 -1)
DB (9) : 20480 20480
ThumbLoaderThread - LOADED from DB (9)
ThumbLoaderThread - loadThumb from DB (9 - ???)
ThumbLoaderThread => 17 (-1 -1)
DB (15890) : 4096 4096
ThumbLoaderThread - LOADED from DB (15890)
ThumbLoaderThread - loadThumb from DB (15890 - ??)
ThumbLoaderThread => 18 (-1 -1)
DB (9496) : 4096 4096
ThumbLoaderThread - LOADED from DB (9496)
ThumbLoaderThread - loadThumb from DB (9496 - ??)
ThumbLoaderThread => 19 (-1 -1)
DB (11) : 4096 4096
ThumbLoaderThread - LOADED from DB (11)
ThumbLoaderThread - loadThumb from DB (11 - ??)
ThumbLoaderThread => 20 (-1 -1)
DB (12) : 4096 4096
ThumbLoaderThread - LOADED from DB (12)
ThumbLoaderThread - loadThumb from DB (12 - ??)
ThumbLoaderThread => 21 (-1 -1)
DB (13) : 36864 36864
ThumbLoaderThread - LOADED from DB (13)
ThumbLoaderThread - loadThumb from DB (13 - ??)
ThumbLoaderThread => 22 (-1 -1)
DB (10781) : 12288 12288
ThumbLoaderThread - LOADED from DB (10781)
ThumbLoaderThread - loadThumb from DB (10781 - ?????)
ThumbLoaderThread => 23 (-1 -1)
DB (8775) : 4096 4096
ThumbLoaderThread - LOADED from DB (8775)
ThumbLoaderThread - loadThumb from DB (8775 - ??)
/usr/lib/gio/modules/libgvfsdbus.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
(<unknown>:3004): Gtk-WARNING **: Error loading theme icon 'window-close' for stock: Unable to load image-loading module: /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: wrong ELF class: ELFCLASS64
(<unknown>:3004): GLib-GObject-CRITICAL **: g_object_unref: assertion `G_IS_OBJECT (object)' failed
** (<unknown>:3004): CRITICAL **: murrine_style_draw_render_icon: assertion `base_pixbuf != NULL' failed
(<unknown>:3004): Gtk-CRITICAL **: IA__gtk_style_render_icon: assertion `pixbuf != NULL' failed
(<unknown>:3004): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_pixels: assertion `GDK_IS_PIXBUF (pixbuf)' failed
(<unknown>:3004): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_width: assertion `GDK_IS_PIXBUF (pixbuf)' failed
(<unknown>:3004): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_height: assertion `GDK_IS_PIXBUF (pixbuf)' failed
Segmentation fault
Re: 0.35 Linux: segfault on ubuntu 11.04
Could you try:
strace ./xnview.sh |& grep -i libqt | grep -v XnViewMP
rmtk
Post by rmtk »
xnview wrote:Could you try:
xnviewmp started and then crashed, without any log in terminal :(
Do you have KDE or QT libs on your ubuntu? Which version of zlib? which version of libxml2?
rmtk
Post by rmtk »
qt:4.7.2; zlib:1.2.3.4; libxml2:2.7.8. All are the default version of ubuntu 11.04.
The segfault can be reproduced on a ubuntu 11.04 64bit livecd.
Ok, there is a problem with gdk/gtk libs. In the .sh add /usr/lib32 in LD_LIBRARY_PATH
rmtk
Post by rmtk »
You mean "export LD_LIBRARY_PATH="$dirname"/lib:/usr/lib32"? But it doesn't work. :|
rmtk wrote:You mean "export LD_LIBRARY_PATH="$dirname"/lib:/usr/lib32"? But it doesn't work. :|
yes, it works for me :( And could you try XnConvert?
rmtk
Post by rmtk »
Just tested on 11.04 livecd again and it did not work either...
xnconvert is ok.
rmtk wrote:Just tested on 11.04 livecd again and it did not work either...
xnconvert is ok.
ok right, i've tested XnConvert not XnViewMP... Gdk try to load some dso, but can't found 32bits version...
