I have a folder with files in different formats. They all should be resized to a new folder, but the filename and the format should be the same:
nconvert -v -truecolors -npcd 2 -size 256x256+0 -ctype grey -corder inter -o X:\resized\%% -ratio -rtype lanczos -rflag decr -resize 200 200 -bgcolor 255 255 255 -canvas 200 200 center -l filelist.txt
My problem: The new files get created without extention. I could not figure out the syntax for -o to just get the same filename in the destination folder.
Any reply is appreciated.
filename problem when resizing (keep format)
jj238095
Re: filename problem when resizing (keep format)
you have no -out option?
jj238095
Hello Pierre,
since I want the output format to be the same as the input I just tried without -out. It seems to work: nconvert does the resizing and leaves the format the same. It's just that the filenames get created witout the extension.
cmd output:
Have a nice weekend!
cmd output:
C:\temp>nconvert -v -npcd 2 -size 256x256+0 -ctype grey -corder inter -ratio -rtype lanczos -rflag decr -resize 200 200 -bgcolor 255 255 255 -canvas 200 200 center -o C:\temp\ncneu\% C:\temp\nconverttest\*.*
** NCONVERT v5.90 (c) 1991-2011 Pierre-E Gougelet (May 12 2011/13:59:51) **
Version for Windows Xp/Vista/7 x64 (All rights reserved)
** This is a freeware software (for non commercial use)
A Adobe Photoshop Document (RGB) - Rle was recognized : C:\temp\nconverttest\here.comes.psd.psd
Width:1920 Height:1200 with 16777216 colors
Nplanes : 3 Bitscount : 8
Bytes Per Plane : 1920
xdpi : 72 ydpi : 72
Resizing : OK
Resizing canvas : OK
Conversion of C:\temp\nconverttest\here.comes.psd.psd into C:\temp\ncneu\here.comes.psd OK
A Portable Network Graphics (RGB) - ZIP was recognized : C:\temp\nconverttest\oh-look-a-png.png
Nplanes : 1 Bitscount : 24
Bytes Per Plane : 5760
xdpi : 96 ydpi : 96
Resizing : OK
Conversion of C:\temp\nconverttest\oh-look-a-png.png into C:\temp\ncneu\oh-look-a-png OK
A Windows Bitmap (RGB) was recognized : C:\temp\nconverttest\some_bmp_01.bmp
xdpi : 96 ydpi : 96
Resizing : OK
Conversion of C:\temp\nconverttest\some_bmp_01.bmp into C:\temp\ncneu\some_bmp_01 OK
A Compuserve GIF (Version 89a) (RGB) - LZW was recognized : C:\temp\nconverttest\this_is_a_gif.gif
Width:1920 Height:1200 with 256 colors
Nplanes : 1 Bitscount : 8
xdpi : 0 ydpi : 0
Resizing : OK
Error: This picture cannot be written using this format (C:\temp\ncneu\this_is_a_gif)
A TIFF (RGB) - LZW was recognized : C:\temp\nconverttest\tif-009.tif
xdpi : 96 ydpi : 96
Resizing : OK
Conversion of C:\temp\nconverttest\tif-009.tif into C:\temp\ncneu\tif-009 OK
C:\temp>pause
Ok, right, i'll fix it
jj238095
Je vous remercie pour votre réponse rapide et pour ses efforts!
