Hello Community,
the HP-GL/2 plugin xemfpcl.usr (unzipped from xemfpcl.zip) from Oleg Kovalenko
(http://www.xnview.com/de/plugins.html)
does not recognize / open .plt files in XnView version 1.98.
("Format of the file <...> could not be determined").
The .plt files were created by a HP 7475A plotter application.
The xemfpcl.usr plugin resides in the PlugIns directory,
and the .plt file type is associated in the Options menu.
Info / Supported Formats lists HPGL-2 as a readable format,
but Info / Plugins Information only list DLLs.
Is there something special to configure in XnView,
or is the xemfpcl.usr plugin outdated / non-functional?
Any hints & tips?
Thank you for your support
Martin
HP-GL/2 plugin xemfpcl.usr from Oleg Kovalenko
martin_u_fischer
Re: HP-GL/2 plugin xemfpcl.usr from Oleg Kovalenko
I'll contact author of plugin...
Peter2
Could you post an example? I'm curious about it.martin_u_fischer wrote:...The .plt files were created by a HP 7475A plotter application....
Peter
martin_u_fischer
Hello Peter,
I´m just new here; where can I put the example?
Regards
Martin
Regards
Martin
Peter2
Not here in the forum. You have to use one of the "upload-websites / share-services".martin_u_fischer wrote:... where can I put the example?...
Peter
martin_u_fischer
Hello Peter,
never used such a service; can I eMail you the example?
Regards
Martin
Regards
Martin
pnielsenz
Hello Pierre (xnview),
Did you ever get a reply from Oleg? Also, where is a file with extension usr supposed to be put to be usable with XnView?
The file xemfpcl.usr has early in the file the words "!This program cannot be run in DOS mode" which suggests that it may be a dll. But I changed the extension, and it doesn't seem to be recognized when put in the plugin directory of XnView anyway.
I need a way other than the proprietary CAD software plugin to be able to view HPGL files.
Peter2
"Plugins user (must be in 'Plugins' directory with .usr extension)"pnielsenz wrote:...Also, where is a file with extension usr supposed to be put to be usable with XnView?...
http://newsgroup.xnview.com/viewtopic.p ... usr#p44272
The best HPGL-Viewer:pnielsenz wrote:...I need a way other than the proprietary CAD software plugin to be able to view HPGL files.
http://www.swplot.com
A plugin for XnView:
http://cadsofttools.com/products/plugin ... -programs/
