Contact sheet filename in two lines
balito
Post by balito »
I'm creating a contact sheet with several images that have long filenames (description of themselves), which must be completely shown.
Everytime I try to create them, the filename is cut off at the end of the first line, showing "...".
Is there a way to show the filename in two or more lines underneath the image?
thanks for your answers.
JohnFredC
Re: Contact sheet filename in two lines
Post by JohnFredC »
Perhaps an improvement to label behavior would be to allow the user to select a "control character" that would cause XnView to wrap the filename at a specific point.
For instance, if the "control character" was defined to be "-", then the following behavior would occur:
Filename:
Label display:
  • This is a
    very long
John
VegasCameraGuy
Post by VegasCameraGuy »
Any movement on this suggestion? When I print a contact sheet it would be nice to have the filename wrap on multiple lines to keep the long filenames from running into each other. I typically only care about the filename and it would be fine to have it wrap over several lines or just be truncated if wrapping is too difficult to accomplish.
