Set comment suggestions
neutrino1200
Post by neutrino1200 »
I organize my pictures collection by putting descriptions on the pictures. (The ones that are stored in the descript.ion file.) The description handling of XnView is good but it can be improved.
If I select one picture with XnView and hit control-D, I can type the description, hit return and the description is applied to that file.
If I select two or more pictures with XnView and hit control-D, I can type the description, but I have to click on the "write all selected" or hit tab three times and then hit return to apply the description to the files. I would like to just hit return when I have multiple files selected and have the description applied to all the files.
In ACDSee 2.4, I can select one file with a description and then select other files without descriptions and apply the description of the first file to all the other files. I cannot seem to do that in XnView. I think I should be able to do it in XnView.
I think that XnView should have a drop-down-box with the last 30 or so descriptions I have used so that I can just click on an arrow and then select one of the descriptions I have already typed in.
