1.98 Bug in 'Copy pathname'
scooterXnview
If you click in the Browser on a file or folder and choose 'Copy pathname' from the context menu, XnView immediately closes. Moreover, XnView copies the pathname of the parent (containing) folder, not of the folder or file marked. I found no hints in the online help if these are the intended actions.
scooterXnview
Re: 1.98 Bug in 'Copy pathname'
By 'right' do you mean that I found an issue or do you mean those were the intended actions?
If you click in the Browser on a file or folder and choose 'Copy pathname' from the context menu, XnView immediately closes …
