defunct jpg -> DDS conversion
gaikokujinkyofusho
Post by gaikokujinkyofusho »
Hi, I tried to batch convert a collection of movie posters from jpg to dds and for some reason xn resized the files and added black space to the DDS file. Here are links to the before
http://dl.dropbox.com/u/507145/1a8c48a7.jpg
and after
http://dl.dropbox.com/u/507145/1a8c48a7.dds
files. I have tried to do additional things like cleaning metadata and resizing the graphics (as opposed to only converting the format) but nada, still defunct dds. Hopefully I am just not doing something right and this is not a bug.
Cheers,
-Gaiko
Re: defunct jpg -> DDS conversion
The output picture must be 4bytes padding...
gaikokujinkyofusho
xnview wrote:The output picture must be 4bytes padding...
Hi Pierre,
Thank you for such a prompt response. Forgive me but what do you mean by the output picture must have a 4byte padding? Meaning that anytime Xn converts something to dds it must add a border to the output dds? If so, is there someway to avoid this? Any suggestions would be greatly appreciated! Regardless thanks for a great program, 3 years of using it and this is the first time I have found it necessary to post (ie normally it does exactly what i need!)
Cheers,
-Gaiko
The width/height must be a power of 2 (current implementation of dds writing)
