New Computer
Mudfan
New Computer
I have just got a new computer, which is Lenovo T61. Can I just move XnView over from my old Compaq, or what is the best way to reinstall it?
Re: New Computer
yes, you can
eL_PuSHeR
Re: New Computer
Yes, just copy the XnView folder inside Program Files folder.
Then the program settings are stored inside => \Users\<YourAccount>\AppData\Roaming (for Vista/7 I think).
For XP they are probably located at => \Documents and settings\<YourAccount>\Program data\Xnview (or something like that).
And to finish, just create some shortcuts.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
