[MP 0.35] Multiple files keyword deletion
Flopin
Post by Flopin »
I am able to add a keyword to several files in one time by clicking on "Save All" button, but if I want to delete a keyword, I have to do it manually for all selected files. Is it normal ? If so, is there any reason for that ?
Thanks for information.
Florent
Re: [MP 0.35] Multiple files keyword deletion
yes, currently i need to find a easier way to do that. Else you have the category panel (near preview)
Vapavite
Post by Vapavite »
Salut Flopin, xnview,
Suggestion :
Créer fenêtre identique à "Editer IPTC/XMP" nommé "Effacement IPTC/XMP". Son seul but serait d'effacer des données, donc lui enlever toutes options et possibilités d'écriture + champs vider par défaut à l'ouverture. Utiliser uniquement la notion "Terme exact" pour les annotations à effacer.
Pour simplifier encore, cette fenêtre pourrait être limitée aux champs au contenu multiple (qui permet le retour chariot tel que mots-clef, catégorie, etc) puisque les autres champs peuvent subir l'effacement par remplacement dans la fenêtre Edition !
Google Translation
Hello Flopin, XnView,
Suggestion:
Create window like "Edit IPTC / XMP" named "Clear IPTC / XMP. Its sole purpose is to erase data so it removed all options and possibilities of writing + empty fields default to open. Use only the concept "exact phrase" to erase annotations.
To simplify, this window could be limited to fields to multiple content (which allows the carriage return as keywords, category, etc.) since the other fields can undergo deletion by replacing, in the Edit window!
Bonne continuation
Vapavite @+
Flopin
Post by Flopin »
xnview wrote:yes, currently i need to find a easier way to do that. Else you have the category panel (near preview)
Vapavite's suggestion sounds good.
