Installing XnviewMP on Debian 6/KDE 4.7
kcredden
Post by kcredden »
Folks: I've been using XnviewMP on linux since MP first came out, but I reciently moved to Debian 6/KDE 4.7, and I can't get MP to work. I tried to run it though the command line, on 2 programs (xnview.sh, and xnview) I get these:
kcredden@zeus:~/PROGRAMS/XnViewMP-035/XnViewMP-035$ ./xnview
./xnview: error while loading shared libraries: libQtWebKitXn.so.4: cannot open shared object file: No such file or directory
and
kcredden@zeus:~/PROGRAMS/XnViewMP-035/XnViewMP-035$ ./xnview.sh
Cannot mix incompatible Qt library (version 0x40703) with this library (version 0x40701)
Aborted
If I try to install the libQtWebKitXn.so.4 file, I get:
kcredden@zeus:~/PROGRAMS/XnViewMP-035/XnViewMP-035$ sudo apt-get install libQtWebKitXn.so.4
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libQtWebKitXn.so.4
E: Couldn't find any package by regex 'libQtWebKitXn.so.4'
Can you help? Gwenview, and others just doesn't cut it. :\
- Kc
Re: Installing XnviewMP on Debian 6/KDE 4.7
could you try to add these files in lib folder?
kcredden
Post by kcredden »
Pierre:
Ok, added them, and got the same errors.
Aborted
If I used ./xnview, it was the same error, as before. Until Debian 6, I always used ./xnview.sh command which worked fine.
I wanted also to add, that 2 of the programs you put in the extras.tgz file, looked to be links (was reading 0 bytes in size). Not sure if that's causing the problem or not.
xnview wrote:could you try to add these files in lib folder?
Could you try
strace ./xnview.sh |& grep -i libqt | grep -v XnViewMP
kcredden
Post by kcredden »
Ok, I copy/pasted that right into a terminal. I got nothing. It just did the command and returned nothing but the cursor.
- Kc
xnview wrote:Could you try
and last line of strace ./xnview.sh?
kcredden
Post by kcredden »
Ok,
First found that strace wasn't installed. But I apt-get installed it, works fine now.
Tried your line again. Same thing. Did nothing,
Lastly: Tried:
kcredden@zeus:~/PROGRAMS/XnViewMP-035/XnViewMP-035$ strace ./xnview.sh
execve("./xnview.sh", ["./xnview.sh"], [/* 39 vars */]) = 0
brk(0)                                  = 0x984a000
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb786d000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY)      = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=76091, ...}) = 0
mmap2(NULL, 76091, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb785a000
close(3)                                = 0
open("/lib/i686/cmov/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240o\1\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1405412, ...}) = 0
mmap2(NULL, 1415560, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xb7700000
mprotect(0xb7853000, 4096, PROT_NONE)   = 0
mmap2(0xb7854000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x153) = 0xb7854000
mmap2(0xb7857000, 10632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb7857000
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb76ff000
set_thread_area({entry_number:-1 -> 6, base_addr:0xb76ff8d0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
mprotect(0xb7854000, 8192, PROT_READ)   = 0
mprotect(0xb788b000, 4096, PROT_READ)   = 0
munmap(0xb785a000, 76091)               = 0
getpid()                                = 2567
rt_sigaction(SIGCHLD, {SIG_DFL, [CHLD], SA_RESTART}, {SIG_DFL, [], 0}, 8) = 0
geteuid32()                             = 1000
brk(0)                                  = 0x984a000
brk(0x986b000)                          = 0x986b000
getppid()                               = 2566
stat64("/home/kcredden/PROGRAMS/XnViewMP-035/XnViewMP-035", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat64(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("./xnview.sh", O_RDONLY)           = 3
fcntl64(3, F_DUPFD, 10)                 = 10
close(3)                                = 0
fcntl64(10, F_SETFD, FD_CLOEXEC)        = 0
rt_sigaction(SIGINT, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGINT, {0x8056520, ~[RTMIN RT_1], 0}, NULL, 8) = 0
rt_sigaction(SIGQUIT, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL, ~[RTMIN RT_1], 0}, NULL, 8) = 0
rt_sigaction(SIGTERM, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigaction(SIGTERM, {SIG_DFL, ~[RTMIN RT_1], 0}, NULL, 8) = 0
read(10, "#!/bin/sh\ndirname=\"$(dirname \"$("..., 8192) = 152
pipe([3, 4])                            = 0
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0xb76ff938) = 2568
close(4)                                = 0
read(3, "/home/kcredden/PROGRAMS/XnViewMP"..., 128) = 50
--- SIGCHLD (Child exited) @ 0 (0) ---
read(3, "", 128)                        = 0
close(3)                                = 0
wait4(-1, [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 2568
clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0xb76ff938) = 2570
wait4(-1, Cannot mix incompatible Qt library (version 0x40703) with this library (version 0x40701)
[{WIFSIGNALED(s) && WTERMSIG(s) == SIGABRT}], 0, NULL) = 2570
write(2, "Aborted\n", 8Aborted
)                = 8
read(10, "", 8192)                      = 0
exit_group(134)                         = ?
Hope that helped!
- Kc
xnview wrote:and last line of strace ./xnview.sh?
Could you post the content of XnViewMP/lib folder?
kcredden
Post by kcredden »
xnview wrote:Could you post the content of XnViewMP/lib folder?
I'm thinking you mean this. A 'ls -la >>lib.txt' list? Here it is.
total 42980
drwxr-xr-x 6 kcredden kcredden     4096 Jun 22 11:22 .
drwxr-xr-x 7 kcredden kcredden     4096 Jun 16 23:33 ..
drwxr-xr-x 2 kcredden kcredden     4096 Dec  3  2010 codecs
drwxr-xr-x 2 kcredden kcredden     4096 Jun 17 08:55 extra
drwxr-xr-x 2 kcredden kcredden     4096 Dec  3  2010 imageformats
lrwxrwxrwx 1 kcredden kcredden       20 May 29 15:56 libphonon.so.4 -> libphononXn.so.4.4.0
lrwxrwxrwx 1 kcredden kcredden       20 May 29 15:56 libphononXn.so.4 -> libphononXn.so.4.4.0
-rwxr-xr-x 1 kcredden kcredden   370928 Dec  3  2010 libphononXn.so.4.4.0
lrwxrwxrwx 1 kcredden kcredden       20 May 29 15:56 libQtCore.so.4 -> libQtCoreXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       20 May 29 15:56 libQtCoreXn.so.4 -> libQtCoreXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden  2931028 Dec  3  2010 libQtCoreXn.so.4.7.1
-rwxrwxrwx 1 kcredden kcredden   537072 Mar 30 12:40 libQtDBusXn.so.4
-rwxrwxrwx 1 kcredden kcredden   537072 Mar 30 12:40 libQtDBusXn.so.4.7
-rwxr-xr-x 1 kcredden kcredden   537072 Mar 30 12:28 libQtDBusXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtGui.so.4 -> libQtGuiXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtGuiXn.so.4 -> libQtGuiXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden 11828024 Dec  3  2010 libQtGuiXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       23 May 29 15:56 libQtNetwork.so.4 -> libQtNetworkXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       23 May 29 15:56 libQtNetworkXn.so.4 -> libQtNetworkXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden  1306132 Dec  3  2010 libQtNetworkXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtSvg.so.4 -> libQtSvgXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtSvgXn.so.4 -> libQtSvgXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden   372128 Dec  3  2010 libQtSvgXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       22 May 29 15:56 libQtWebKit.so.4 -> libQtWebKitXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       22 May 29 15:56 libQtWebKitXn.so.4 -> libQtWebKitXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden 20309160 Dec  3  2010 libQtWebKitXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       27 May 29 15:56 libQtXmlPatterns.so.4 -> libQtXmlPatternsXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       27 May 29 15:56 libQtXmlPatternsXn.so.4 -> libQtXmlPatternsXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden  4931076 Dec  3  2010 libQtXmlPatternsXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtXml.so.4 -> libQtXmlXn.so.4.7.1
lrwxrwxrwx 1 kcredden kcredden       19 May 29 15:56 libQtXmlXn.so.4 -> libQtXmlXn.so.4.7.1
-rwxr-xr-x 1 kcredden kcredden   303936 Dec  3  2010 libQtXmlXn.so.4.7.1
-rw-r--r-- 1 kcredden kcredden        0 Jun 22 11:22 lib.txt
drwxr-xr-x 2 kcredden kcredden     4096 Dec  3  2010 phonon_backend
And could you try XnConvert? Tell me if you have the same problem?
kcredden
Post by kcredden »
Pierre
Ok, first, thanks for the .DEB file. 8 minutes from download to dpkg. Installed like a charm.
Now however, the bad news:
kcredden@zeus:~/TH-zeus/inbox$ xnconvert
/opt/XnConvert/xnconvert.sh: line 5:  2072 Aborted                 "$dirname"/xnconvert "$@"
I'm seeing that it's basically the same problem.
xnview wrote:And could you try XnConvert? Tell me if you have the same problem?
I've installed Debian 6, but i have only Qt 4.6.3
How to update for 4.7?
kcredden
Post by kcredden »
Pierre:
Ok, I'm trying this command
aptitude install qtcreator
and here is what showed up, while installing.
kcredden@zeus:~$ sudo aptitude install qtcreator
[sudo] password for kcredden:
The following NEW packages will be installed:
  gdb{a} gdbserver{a} libgl1-mesa-dev{a} libglu1-mesa-dev{a} libpthread-stubs0{a} libpthread-stubs0-dev{a}
  libqt4-declarative{a} libqt4-declarative-gestures{a} libqt4-declarative-particles{a} libqt4-dev{a}
  libqt4-help{a} libqt4-opengl-dev{a} libqt4-scripttools{a} libqt4-sql-sqlite{a} libqt4-test{a}
  libqtwebkit-dev{a} libx11-dev{a} libxau-dev{a} libxcb1-dev{a} libxdmcp-dev{a} libxext-dev{a} make{a}
  mesa-common-dev{a} multiarch-support{a} qt4-demos{a} qt4-designer{a} qt4-dev-tools{a} qt4-doc{a}
  qt4-qmake{a} qtcreator qtcreator-doc{a} x11proto-core-dev{a} x11proto-input-dev{a} x11proto-kb-dev{a}
  x11proto-xext-dev{a} xorg-sgml-doctools{a} xtrans-dev{a}
The following packages will be REMOVED:
  cpp-4.4{u} libavutil49{u} libboost-program-options1.42.0{u} libeggdbus-1-0{u} libgmp3c2{u} libgs8{u}
  libpango1.0-common{u} librasqal2{u} libxcb-dri2-0{u} libxcb-render-util0{u} xulrunner-1.9.1{u}
The following packages will be upgraded:
  libc-bin libc6 libx11-6 libxau6 libxcb1 libxdmcp6 libxext6
7 packages upgraded, 37 newly installed, 11 to remove and 266 not upgraded.
Need to get 156 MB of archives. After unpacking 207 MB will be used.
The following packages have unmet dependencies:
  libc6-i686: PreDepends: libc6 (= 2.13-4) but 2.13-7 is to be installed.
Internal error: found 2 (choice -> promotion) mappings for a single choice.
The following actions will resolve these dependencies:
     Remove the following packages:
1)     libc6-i686
     Leave the following dependencies unresolved:
2)     libc6 recommends libc6-i686
3)     linux-image-2.6.32-5-686 recommends libc6-i686
4)     linux-image-2.6.38-2-686 recommends libc6-i686
Accept this solution? [Y/n/q/?] y
  cpp-4.4{u} libavutil49{u} libboost-program-options1.42.0{u} libc6-i686{a} libeggdbus-1-0{u} libgmp3c2{u}
  libgs8{u} libpango1.0-common{u} librasqal2{u} libxcb-dri2-0{u} libxcb-render-util0{u} xulrunner-1.9.1{u}
7 packages upgraded, 37 newly installed, 12 to remove and 265 not upgraded.
Need to get 156 MB of archives. After unpacking 204 MB will be used.
Do you want to continue? [Y/n/?] y
Get:1 http://ftp.debian.org/debian/ testing/main libc-bin i386 2.13-7 [1,022 kB]
Get:2 http://ftp.debian.org/debian/ testing/main libc6 i386 2.13-7 [3,892 kB]
it's going to be about 1.5 hours doing this (I have a SLOW broadband :\) but the system's imaged, incase it shafts the system. Will write back with results.
- Kc
xnview wrote:I've installed Debian 6, but i have only Qt 4.6.3
I've tried, but no problem...
Could you send me output of "ls -l /usr/lib/libQt*"
kcredden
Post by kcredden »
Here you go!
-rw-r--r-- 1 root root      651 May  8 21:08 /usr/lib/libQt3Support.prl
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQt3Support.so -> libQt3Support.so.4.7.3
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQt3Support.so.4 -> libQt3Support.so.4.7.3
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQt3Support.so.4.7 -> libQt3Support.so.4.7.3
-rw-r--r-- 1 root root  2970116 May  8 21:09 /usr/lib/libQt3Support.so.4.7.3
-rw-r--r-- 1 root root      655 May  8 21:08 /usr/lib/libQtCLucene.prl
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtCLucene.so -> libQtCLucene.so.4.7.3
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtCLucene.so.4 -> libQtCLucene.so.4.7.3
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtCLucene.so.4.7 -> libQtCLucene.so.4.7.3
-rw-r--r-- 1 root root   853532 May  8 21:09 /usr/lib/libQtCLucene.so.4.7.3
-rw-r--r-- 1 root root      644 May  8 21:08 /usr/lib/libQtCore.prl
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtCore.so -> libQtCore.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtCore.so.4 -> libQtCore.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtCore.so.4.7 -> libQtCore.so.4.7.3
-rw-r--r-- 1 root root  2775480 May  8 21:09 /usr/lib/libQtCore.so.4.7.3
-rw-r--r-- 1 root root      656 May  8 21:08 /usr/lib/libQtDBus.prl
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtDBus.so -> libQtDBus.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtDBus.so.4 -> libQtDBus.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtDBus.so.4.7 -> libQtDBus.so.4.7.3
-rw-r--r-- 1 root root   503100 May  8 21:09 /usr/lib/libQtDBus.so.4.7.3
-rw-r--r-- 1 root root      655 May  8 21:08 /usr/lib/libQtDeclarative.prl
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtDeclarative.so -> libQtDeclarative.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtDeclarative.so.4 -> libQtDeclarative.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtDeclarative.so.4.7 -> libQtDeclarative.so.4.7.3
-rw-r--r-- 1 root root  3414000 May  8 21:09 /usr/lib/libQtDeclarative.so.4.7.3
-rw-r--r-- 1 root root      586 May  8 21:08 /usr/lib/libQtDesignerComponents.prl
lrwxrwxrwx 1 root root       32 May  8 21:09 /usr/lib/libQtDesignerComponents.so -> libQtDesignerComponents.so.4.7.3
lrwxrwxrwx 1 root root       32 May  8 21:09 /usr/lib/libQtDesignerComponents.so.4 -> libQtDesignerComponents.so.4.7.3
lrwxrwxrwx 1 root root       32 May  8 21:09 /usr/lib/libQtDesignerComponents.so.4.7 -> libQtDesignerComponents.so.4.7.3
-rw-r--r-- 1 root root  2600600 May  8 21:09 /usr/lib/libQtDesignerComponents.so.4.7.3
-rw-r--r-- 1 root root      541 May  8 21:08 /usr/lib/libQtDesigner.prl
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQtDesigner.so -> libQtDesigner.so.4.7.3
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQtDesigner.so.4 -> libQtDesigner.so.4.7.3
lrwxrwxrwx 1 root root       22 May  8 21:09 /usr/lib/libQtDesigner.so.4.7 -> libQtDesigner.so.4.7.3
-rw-r--r-- 1 root root  6117728 May  8 21:09 /usr/lib/libQtDesigner.so.4.7.3
-rw-r--r-- 1 root root      672 May  8 21:08 /usr/lib/libQtGui.prl
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtGui.so -> libQtGui.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtGui.so.4 -> libQtGui.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtGui.so.4.7 -> libQtGui.so.4.7.3
-rw-r--r-- 1 root root 11304464 May  8 21:09 /usr/lib/libQtGui.so.4.7.3
-rw-r--r-- 1 root root      651 May  8 21:08 /usr/lib/libQtHelp.prl
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtHelp.so -> libQtHelp.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtHelp.so.4 -> libQtHelp.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtHelp.so.4.7 -> libQtHelp.so.4.7.3
-rw-r--r-- 1 root root   544428 May  8 21:09 /usr/lib/libQtHelp.so.4.7.3
lrwxrwxrwx 1 root root       22 Mar 24 16:59 /usr/lib/libQtLocation.so.1 -> libQtLocation.so.1.2.0
lrwxrwxrwx 1 root root       22 Mar 24 16:59 /usr/lib/libQtLocation.so.1.2 -> libQtLocation.so.1.2.0
-rw-r--r-- 1 root root  1322452 Mar 24 16:59 /usr/lib/libQtLocation.so.1.2.0
lrwxrwxrwx 1 root root       27 Mar 24 16:59 /usr/lib/libQtMultimediaKit.so.1 -> libQtMultimediaKit.so.1.2.0
lrwxrwxrwx 1 root root       27 Mar 24 16:59 /usr/lib/libQtMultimediaKit.so.1.2 -> libQtMultimediaKit.so.1.2.0
-rw-r--r-- 1 root root   807048 Mar 24 16:59 /usr/lib/libQtMultimediaKit.so.1.2.0
-rw-r--r-- 1 root root      647 May  8 21:08 /usr/lib/libQtNetwork.prl
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtNetwork.so -> libQtNetwork.so.4.7.3
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtNetwork.so.4 -> libQtNetwork.so.4.7.3
lrwxrwxrwx 1 root root       21 May  8 21:09 /usr/lib/libQtNetwork.so.4.7 -> libQtNetwork.so.4.7.3
-rw-r--r-- 1 root root  1290400 May  8 21:09 /usr/lib/libQtNetwork.so.4.7.3
-rw-r--r-- 1 root root      670 May  8 21:08 /usr/lib/libQtOpenGL.prl
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtOpenGL.so -> libQtOpenGL.so.4.7.3
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtOpenGL.so.4 -> libQtOpenGL.so.4.7.3
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtOpenGL.so.4.7 -> libQtOpenGL.so.4.7.3
-rw-r--r-- 1 root root   978316 May  8 21:09 /usr/lib/libQtOpenGL.so.4.7.3
-rw-r--r-- 1 root root      673 May  8 21:08 /usr/lib/libQtScript.prl
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtScript.so -> libQtScript.so.4.7.3
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtScript.so.4 -> libQtScript.so.4.7.3
lrwxrwxrwx 1 root root       20 May  8 21:09 /usr/lib/libQtScript.so.4.7 -> libQtScript.so.4.7.3
-rw-r--r-- 1 root root  2578604 May  8 21:09 /usr/lib/libQtScript.so.4.7.3
-rw-r--r-- 1 root root      655 May  8 21:08 /usr/lib/libQtScriptTools.prl
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtScriptTools.so -> libQtScriptTools.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtScriptTools.so.4 -> libQtScriptTools.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtScriptTools.so.4.7 -> libQtScriptTools.so.4.7.3
-rw-r--r-- 1 root root   741284 May  8 21:09 /usr/lib/libQtScriptTools.so.4.7.3
-rw-r--r-- 1 root root      639 May  8 21:08 /usr/lib/libQtSql.prl
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSql.so -> libQtSql.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSql.so.4 -> libQtSql.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSql.so.4.7 -> libQtSql.so.4.7.3
-rw-r--r-- 1 root root   259128 May  8 21:09 /usr/lib/libQtSql.so.4.7.3
-rw-r--r-- 1 root root      639 May  8 21:08 /usr/lib/libQtSvg.prl
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSvg.so -> libQtSvg.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSvg.so.4 -> libQtSvg.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtSvg.so.4.7 -> libQtSvg.so.4.7.3
-rw-r--r-- 1 root root   349192 May  8 21:09 /usr/lib/libQtSvg.so.4.7.3
-rw-r--r-- 1 root root      644 May  8 21:08 /usr/lib/libQtTest.prl
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtTest.so -> libQtTest.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtTest.so.4 -> libQtTest.so.4.7.3
lrwxrwxrwx 1 root root       18 May  8 21:09 /usr/lib/libQtTest.so.4.7 -> libQtTest.so.4.7.3
-rw-r--r-- 1 root root   138908 May  8 21:09 /usr/lib/libQtTest.so.4.7.3
-rw-r--r-- 1 root root  1106838 May  8 21:09 /usr/lib/libQtUiTools.a
-rw-r--r-- 1 root root      523 May  8 21:08 /usr/lib/libQtUiTools.prl
-rw-r--r-- 1 root root      589 Apr  9 07:59 /usr/lib/libQtWebKit.prl
lrwxrwxrwx 1 root root       20 Apr  9 08:54 /usr/lib/libQtWebKit.so -> libQtWebKit.so.4.8.0
lrwxrwxrwx 1 root root       20 Apr  9 08:54 /usr/lib/libQtWebKit.so.4 -> libQtWebKit.so.4.8.0
lrwxrwxrwx 1 root root       20 Apr  9 08:54 /usr/lib/libQtWebKit.so.4.8 -> libQtWebKit.so.4.8.0
-rw-r--r-- 1 root root 21725672 Apr  9 08:55 /usr/lib/libQtWebKit.so.4.8.0
-rw-r--r-- 1 root root      655 May  8 21:08 /usr/lib/libQtXmlPatterns.prl
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtXmlPatterns.so -> libQtXmlPatterns.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtXmlPatterns.so.4 -> libQtXmlPatterns.so.4.7.3
lrwxrwxrwx 1 root root       25 May  8 21:09 /usr/lib/libQtXmlPatterns.so.4.7 -> libQtXmlPatterns.so.4.7.3
-rw-r--r-- 1 root root  4189580 May  8 21:09 /usr/lib/libQtXmlPatterns.so.4.7.3
-rw-r--r-- 1 root root      639 May  8 21:08 /usr/lib/libQtXml.prl
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtXml.so -> libQtXml.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtXml.so.4 -> libQtXml.so.4.7.3
lrwxrwxrwx 1 root root       17 May  8 21:09 /usr/lib/libQtXml.so.4.7 -> libQtXml.so.4.7.3
-rw-r--r-- 1 root root   266488 May  8 21:09 /usr/lib/libQtXml.so.4.7.3
xnview wrote:I've tried, but no problem...
