Can not write IPTC keywords anymore
Asmo
Post by Asmo »
Hello, just updated xnview (1.98.1 dutch win7 home), and now I can not write/delete/add iptc keywords, descritpion, etc. anymore on the photo's i made with my digital camera Samsung wb650. If I do the same on images from my mobile phone (samsung s8300) it works OK. The previous version I used 1.97.8 it worked without problems...
I uploaded a image where I have problems with here: http://www.peatfreak.com/_etc/2011-06-1 ... _002_O.JPG
Note that I can not edit *any* photo's the iptc data if it was shot with the wb650.
I will downgrade as I constantly have to use this for my work, hope i provided you all the info you need to track it doen, and it isnt a stupid user error :)
Re: Can not write IPTC keywords anymore
Right, your jpeg file has a MPF block (MultiPictureFormat) like MPO format :(
Asmo
Post by Asmo »
I have no idea what that means for you as a developper... I hope it can be fixed as before it worked fine....
Good luck with it,
Jeroen
your photo is the original from your camera?
Asmo
Post by Asmo »
Yes, only thing I did was adding iptc keywords in your working version before. If you want, i could take anew photo and upload to my web if you want a absolutely clean image.
So, the one you have now is only editted in xnview, adding iptc keywords in older version.
Just let me know :)
Asmo wrote:Yes, only thing I did was adding iptc keywords in your working version before. If you want, i could take anew photo and upload to my web if you want a absolutely clean image.
Yes please
Asmo
Post by Asmo »
http://www.peatfreak.com/_etc/SAM_1541.JPG
Hope this helps you! I took this photo, put the card in the cardreader and uploaded per FTP straight from the card, without copying it first to my harddisk.
Asmo wrote:http://www.peatfreak.com/_etc/SAM_1541.JPG
Ok, in this file, you have multiple image... I'll fix the problem...
Asmo
Post by Asmo »
Great, thanks!
Asmo
Post by Asmo »
Its fixed, thanks! :D
