webp
debianuser2010
webp
Post by debianuser2010 »
The feature description on the main web page says XnConvert supports webP:
All common picture and graphics formats are supported (i.e. JPG, PNG, TIFF, GIF, Camera RAW, JPEG2000, WebP, OpenEXR)
However, after I downloaded and installed version 1.02 for Debian it does not save as webp, nor does it recognize webp files for input. Am I missing something?
Thanks!
Re: webp
Right, the plugin is missing on linux...
debianuser2010
Re: webp
ETA on a fix?
Re: webp
fixed in 1.10
debianuser2010
Re: webp
Thanks! :-)
-oX-
Re: webp
Post by -oX- »
Could you please add the possibility to save for an wished filesize..
or to use a preset
i see this option in the commandline version of webp-encoder
its possible to write the used version of weppy into the settingswindow?
or its possible to use external encoder (with option to hide the dos-box)?
tnx
Re: webp
Please check XnViewMP 0.48
