Pressing Tab crashes XnView
Hacker
Post by Hacker »
XnView 1.98.1
Windows 7 Enterprise 64-bit
clean .ini
From Explorer click on an image file (any JPG will do). XnView will open the image. Press Tab a few times. XnView crashes.
Roman
Hacker
Re: Pressing Tab crashes XnView
Post by Hacker »
Bug still present in 1.98.2. :( Perhaps it's related to my multi-monitor setup?
marsh
Post by marsh »
I could not recreate this with v.1.98.1. One monitor. Could another program be interfering with or sharing use of the key? Just speculating.
Hacker
Post by Hacker »
marsh,
I don't think so. If Tab would be caught by another program it should not crash XnView anyways.
Are you able to reproduce this bug each time?
Dreamer
Post by Dreamer »
Can't confirm with 1.98.2, Windows Vista, 32 bit.
Dreamer
