Auto Image Size: Fit window to image & Force XnView to ...
robur
Post by robur »
Hello there,
I'm using the latest version (1.98.1) of XnView, view settings:
Auto Image Size: "Fit window to image" with "Force XnView to Fit Image" active.
That way, I can see images smaller than my screen resolution without any borders when looking at more of them at one time.
However, this only works for images that are smaller or equal size as the screen resolution. If images are higher/wider, XnView goes to max screen hight/width, but the image of course is still bigger.
Is there a way to set it that in this case, the image would shrink automatically so it could be seen without needing to manually shrink it?
I really love the other viewing behaviour, it's just those really big images that leave me puzzled.
Thanks much!
