Well, it's not a "bug" but the behaviour does not fit the way I work...
When I select a file then click another time on it, MP considered it as a double-click and select the name to be changed. It's just boring because I select often two times a file when working (changing application by example). And it's not a all a common use of selection !
Click two times
lian
Click two times
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
