I have a little request. If you right click on an item like category, folder or bookmark in a corresponding panel, e.g. because you want to rename or delete it, it's content gets displayed in the browse view. I think this is an unusual behaviour (at least in Windows). I would expect the context menu get's opened without any further actions - like it's handled in the Info --> Categories Panel.
Example of the default Windows behavior:
In the Explorer or any save/load-dialog right click in the tree view on an entry - an context menu gets opened, but the actual directory does not get switched.
Right click on folders/categories/etc should not load them
vommie
vommie
Re: Right click on folders/categories/etc should not load th
Wow, you fulfilled this wish faster than a fairy
Of course I hope you expand this behaviour also on the folders and favorites view, but categories was the most important, thanks.
And no problem?vommie wrote:Wow, you fulfilled this wish faster than a fairy
vommie
It works exactly as I imagined. So: no problems -it's true
