MP 0.38 Win: Browser list don't display folder
PBY
The browser list view don't display folders (at least with Images filter), navigation need to be done in the tree view. This isn't very comfortable, and isn't the normal behavior (old XnView allowed it).
PBY
Re: MP 0.38 Win: Browser list don't display folder
You can customize files that you want to see
PBY
I can only customize for the "Custom" filter. I didn't found any way for displaying also folders in "Images" folder.
On a normal screen, it isn't very troublesome, the folders panel is visible, but on the netbook, Folders panel need to be pined to be able to see something. For just changing of one folder, it is a bit troublesome to display the panel, do the change, and hide again the panel.
PBY
It was a previous discussion about this difference between XnView and XnViewMP, and folder was removed from Images filter.PBY wrote:I can only customize for the "Custom" filter. I didn't found any way for displaying also folders in "Images" folder.
Perhaps i can add checkbox 'Show Subfolder' in filter menu??
PBY
Such option would be great. Also, don't forget the parent folder (..)
I understand that some users don't want to see folders when looking for images, but this depends of how the user create his file structure (I don't have have subfolders in folder containing photo, but a folder for every day/topic)
PBY
But why you don't use 'Custom'??PBY wrote:Such option would be great. Also, don't forget the parent folder (..)
