automatic levels - ctrl-alt-L doesn't work
wOlrik
Post by wOlrik »
I don't know if it's a bug or if something else is intercepting the key combo. Sometimes XNview loses focus when I try the key combo, even when only XNview is running. Is it a bug? and if not, where do I look to correct the problem?
Re: automatic levels - ctrl-alt-L doesn't work
Do you have a way to reproduce?
wOlrik
Post by wOlrik »
Reproduce? It simply doesn't work at all.
Is there a way I can have a button for it?
It works for me, i open an image from browser, Ctrl+Alt+L it's ok
wOlrik
Post by wOlrik »
Unfortunately, the fact that it works for you doesn't help me. :)
yes i know :) but it's difficult to find the problem...
And other shortcuts work?
wOlrik
Post by wOlrik »
I sorted it, thanks. :) I'd guessed there was a global shortcut installed that was using ctrl-alt-L, and I finally found it is a program I use called Sticky Passwords. :evil: Luckily it allowed me to change the key combination so that ctrl-alt-L is available to XNView again. If only *all* programs allowed you to change the shortcuts. ;)
