Batch renaming a dozen jpegs with following settings will not work in 0.38.2 (they are not renamed).
[x]Name template
abcd_{Filename}
Renaming with other '[x]Replace' section is working so far.
v.0.38.2 batch rename by template not working
marsh
Re: v.0.38.2 batch rename by template not working
All is ok with dialog, but after pressing ok, no rename? And for 2 files?
marsh
No effect with 2 files also. No history of name template is kept also.
And in filelist, the output name is ok?? It works for memarsh wrote:No effect with 2 files also. No history of name template is kept also.
marsh
An acceptable name was used, nothing to conflict with existing names. Maybe it is wine problem (though all your programs usually work well under it).xnview wrote:And in filelist, the output name is ok?? It works for memarsh wrote:No effect with 2 files also. No history of name template is kept also.
And with 0.35 win, no problem?marsh wrote:An acceptable name was used, nothing to conflict with existing names. Maybe it is wine problem (though all your programs usually work well under it).xnview wrote:And in filelist, the output name is ok?? It works for memarsh wrote:No effect with 2 files also. No history of name template is kept also.
marsh
No problem with 0.35 (using .38's ini).
Could you make a screenshot of the dialog? And duplicate dialog too?marsh wrote:No problem with 0.35 (using .38's ini).
marsh
And if you use 'replace', it works?
marsh
Replace works on all versions
Ok, i the list was empty...
marsh
The updated v.0.38.3 resolves this problem. Thanks.
