Hi there, I have photos that are set out as a folder hierachy on the computer.
They are all tagged. So I'd like to start at the absolute root of all my folders and start typing in tag names - I think it would be awesome for XnView MP to be able to display these tags dynamically from all the child folders. Combined with multiple tags this could be a powerful features.
For example: If I start on my absolute root photo folder and type in:
Outdoor, trees, overcast
XnViewMP will search all child photo's tags and display photos containing all these keywords. And if I were to type this:
Outdoor, trees, overcast -flash
It would do exactly the same but remove the photos with the "flash" tag.
Hope that makes sense!
Request: searching sobfolders with tags
Re: Request: searching sobfolders with tags
Currently the only way is to use 'search'
UrbanCoyote
Thanks, Pierre. Is something like this possible to add though long-term?
I think it's useful since XnView uses a database, to be able to manage many thousands of images and search this database would make it quite powerful. Pretty much exactly how Picasa works when searching images.
