Here are the images that are just copied from SD card.
Then IPTC/XMP data are batch added.
XnView is closed and re-opened. Info icons and Exif Date disappear!
MP 0.38.4 Win: Info icons and Exif Date disappear
afatac
afatac
Re: MP 0.38.4 Win: Info icons and Exif Date disappear
Tested on MP 0.38.5.
After adding/editing the metadata, the info icons are displayed, but one icon is missing. The one with a white box within a box. What is this icon away?
As for the Exif Date, they do not appear immediately after adding/editing metadata. But by switching the view to other folder and returning, the Exif Date will appear.
New Observation:
When I open a folder that contain images which the metadata are added/edited using XnView 1.98.1, only one icon is shown and Exif Date is not shown.
New Observation:
- Forum Librarian
afatac wrote:After adding/editing the metadata, the info icons are displayed, but one icon is missing. The one with a white box within a box. What is this icon away?
helmut (FAQ: [url=http://newsgroup.xnview.com/viewtopic.php?p=15818#p15818]What do the info icons on the thumbnail mean?[/url]) wrote:Small square: For displaying the thumbnail of this image, the embedded JPG thumbnail is used.
afatac
Thank you for the info.XnTriq wrote:afatac wrote:After adding/editing the metadata, the info icons are displayed, but one icon is missing. The one with a white box within a box. What is this icon away?helmut (FAQ: [url=http://newsgroup.xnview.com/viewtopic.php?p=15818#p15818]What do the info icons on the thumbnail mean?[/url]) wrote:Small square: For displaying the thumbnail of this image, the embedded JPG thumbnail is used.
In that case, XnView 1.98.1 is not handling this correctly because there is no Exif thumbnail in my images, which are taken by using a compact digital camera.
afatac
Correction. There is Exif thumbnail in my images after verifying this using other application.In that case, XnView 1.98.1 is not handling this correctly because there is no Exif thumbnail in my images, which are taken by using a compact digital camera.
