v.0.38 Drag and drop to batch convert tab
marsh
Post by marsh »
Batch convert sometimes appears in a tab. As long is this happens, files from browser should be dragged and dropped on its tab in my opinion.
Re: v.0.38 Drag and drop to batch convert tab
you have Convert in a tab if you press CTRL key
marsh
Post by marsh »
Aha. That explains it. However, then keyboard people and mouse people will see something different. Because of this, would the opposite CTRL+mousebutton for non-tab be better?
marsh wrote:Aha. That explains it. However, then keyboard people and mouse people will see something different. Because of this, would the opposite CTRL+mousebutton for non-tab be better?
Currently it's experimental, so for advanced user to see if 'batch convert' as a tab is good...
budz45
Post by budz45 »
I still havn't a clue how to access this 'tab' method. Is this batch convert 'tab' the same way as the 'Compare' tab in XnView MP?
Is I press Ctrl+U then the standard modal window (own tabbed interface) displays. BTW 'Ctrl' and 'Shift' keys are modifier keys so I don't understand how the 'Ctrl' key can be used by itself to access this experimental feature.
http://newsgroup.xnview.com/viewtopic.php?p=94050
In the Browser I select a picture, press the CTRL key and nothing happens, please advise what I'm doing wrong.
I'm running MP 0.39
Press shift when you click on 'batch convert'
budz45
Post by budz45 »
xnview wrote:Press shift when you click on 'batch convert'
Ah haaa got it :D
Here is a screenshot for everyone:
All I can say is that I really like this method (as a tab) and I fully understand JohnFredC's concepts of this display and trying to keep a non-modal approach. I like this batch-convert as tab a lot :-)
Why Pierre, in the first place, did you mention "CTRL" instead of simply saying "Shift"? Anyway doesn't matter.
budz45 wrote:Why Pierre, in the first place, did you mention "CTRL" instead of simply saying "Shift"? Anyway doesn't matter.
I've change it
