v.0.38 Search wildcard
marsh
Post by marsh »
When using search tool wildcard and a partial word:
"test*.*" works (two asterisks shouldn't be needed)
"test*" does not work (the better form to use)
Re: v.0.38 Search wildcard
You means the Search dialog??
test* works for me...
marsh
Post by marsh »
Yes, specifically for condition field. Ex. Iptc:all fields 'is any of' test* (in <ctrl + f> search dialog). Looking for keyword of 'testing'.
I don't have problem with the filename field however. It accepts a single *.
marsh wrote:Yes, specifically for condition field. Ex. Iptc:all fields 'is any of' test* (in <ctrl + f> search dialog). Looking for keyword of 'testing'.
Oh ok. No it's normal. Search use for 'is any of' a regular expression, so any letters following is '.*'
marsh
Post by marsh »
Thanks for the reminder. I didn't need to use a wildcard in first place since the option 'contains' performed partial word search fine. I'm safe from reading my old regular expression chart for a while. :)
