It seems that both the 'next/prev file' controls in the Viewer are not getting greyed out if I navigate to the very end of the file list (last image file in folder/file list so ">>" should be greyed out)
....or same if I navigate to the very beginning of a file list (first image file in folder/file list so "<<" should be gryed out).
So toolbar icons for these two need to be greyed out, just the same as "next/prev page" (for Multipage files) already does this.
This should be quite easy to fix by the looks of things
Thank you.
MP 0.38.5 Win: The 'next/prev file' not greyed out at end
budz45
budz45
Re: MP 0.38.5 Win: The 'next/prev file' not greyed out at en
Ok,
this is a strange issue, because in other times, the grey out does work.
I will do some tests and try to make a
reproduce later..
