Make some window panels resizable
mrwul
Post by mrwul »
Whilst being a happy XnView user, I'd like to suggest to have some window panels
resizable. Have asked this before.
Example, when using the batch rename context menu and entering long filename, I would
prefer the window panel to be resizable.
Also the Replace [___] and with [___] box should be bigger, something like this.
BTW I am using W7 64bit.
TIA
JohnFredC
Re: Make some window panels resizable
Post by JohnFredC »
I use a 3rd party tool for that: Sizer.
A Search reveals one or two others also available.
John
mrwul
Post by mrwul »
I know, but I think it should be handled by XnView and that aside, I am using 64bit, so I cannot use Sizer.
Regretfully so.
Also, I guess, the replace boxes remain unchanged in width ?
mrwul
Post by mrwul »
Regret, not even a single word of feedback from the developer... Think this is not such a bad idea. :(
It's not easy to make dialog resizable
mrwul
Post by mrwul »
Maybe fixed larger window size then,
and
have the text-boxes larger, see my example.
JohnFredC
Post by JohnFredC »
Perhaps don't use a dialog... use regular, resizeable form.
John
