Function "remove alpha channel" wanted - another time
TD
Post by TD »
I regularly use Enfuse to blend some files into one and save the result as a 16-bit tif file. Enfuse always saves these files with an alpha channel.
Now what I really would like to have is a possibility in XnView to remove the alpha channel of these files.
Have a nice day!
Edit: Ok, I found "Ignore aplpha channel" und removed the sentence about displaying the thumnails. But I still would like a possibility to remove the alpha channel of 16-bit tif files.
Re: Function "remove alpha channel" wanted - another time
You can use 'convert 24bits'
