Support for .GPL (gimp) palettes
Hobbe
Post by Hobbe »
Hello. I'd like to request support for this type of palette. The one supported by XnView and the one I'm talking about are nearly identical. It seems to me it that would be a matter of merely allowing the .GPL extension plus 3 different lines for the header.
I've attached 2 test palettes, one generated with XnView (.gimp) and one generated by another application (.GPL) so you get a better idea. Right now XnView is unable to import/export .GPL's, which have become pretty popular.
Thanks for your time and keep up the good work 8)
Re: Support for .GPL (gimp) palettes
Ok, i'll check
Hobbe
Post by Hobbe »
Thank you very much sir for taking this into consideration :)
