{File Index} should take into account folders?
Zheitk
I have a folder with 2 folders, and the first image has an index of 4/35, it seems to be taking into account the "green arrow" that access to the parent directory and the other two folders. I think it would be nice to have another option to only take into account the existing files.
Re: {File Index} should take into account folders?
in fullscreen?
Zheitk
Yes, in the box that appears in the fullscreen, in Settings => View => Info
also, is there any way to remove the green arrow?
Yes, it's a known issueZheitk wrote:Yes, in the box that appears in the fullscreen, in Settings => View => Info
Which green arrow?also, is there any way to remove the green arrow?
- Forum Librarian
Parent folder ('..') can be deactivated in Tools » Settings... » Browser » File list » Custom filter.xnview wrote:Which green arrow?also, is there any way to remove the green arrow?
Zheitk
(= ̮ ̮ =)xnview wrote:Yes, it's a known issue
Thanks, I never thought it can be deactivated thereXnTriq wrote:Parent folder ('..') can be deactivated in Tools » Settings... » Browser » File list » Custom filter.
