Settings layout Correction
thibaud
Post by thibaud »
Another Setting screen that is currently wrong:
thibaud
Re: Settings layout Correction
Post by thibaud »
Actually now that I re-think of it...
When referring to the space surrounding the image thumbnail itself,
"Padding" should be renamed to "Margin" if moved into the "Thumbnail" group like I suggested.
(for the sake of symmetry you could even rename it to "Spacing" to match the "Thumbnail cell" term)
budz45
Post by budz45 »
Good suggestions, I'm sure Pierre would read and approve of them if he finds no conflict of opinion. :)
I liked how you previously spotted a previous UI mishap in the 'Settings' and it then later got resolved; http://newsgroup.xnview.com/viewtopic.p ... 16&p=95401 :)
Vapavite123
Post by Vapavite123 »
This seems more correct (Translation Fr)
VignetteApparence copier.jpg (35.86 KiB) Viewed 822 times
Your
