RC5: multiple separators at the end of the toolbar
scratch
depending on how many buttons you hide, you can end up with two or three separators at the end of a given toolbar. i would suggest that you check if there are any buttons visible after the separator, and if not, hide the separator too. this occurs both in browser and view.
XnView 1.80 <x>
XnView 1.80 <x>
A pinch OT---
- This occurs because the separators are not configurable at all, while they are in the most programs where you may configure such buttons on (a) tool-bar(s).
- This is a pinch OT, but I guess that the separators should be in the button-list as an item; so, the user could place them like he/she needs…
scratch
A fixed bunch
- Indeed, a minimal default ones must be displayed for the default tool-bar at the first start-up, but they might be removed as soon as you open the Option >> Buttons…
Re: RC5: multiple separators at the end of the toolbar
Strange, i remove separator. Could you tell me which button do you have enabled?scratch wrote:depending on how many buttons you hide, you can end up with two or three separators at the end of a given toolbar. i would suggest that you check if there are any buttons visible after the separator, and if not, hide the separator too. this occurs both in browser and view.
scratch
An item, plz
- What about my proposal above ? I mean : set "Separator" as an item in the list of buttons; I guess that the current layout - not configurable- wastes room on the screen in many cases, and I would wish to get only the really indispensable separators… For 1.81 ?
Re: An item, plz
Yes, not in 1.80Clo wrote:- What about my proposal above ? I mean : set "Separator" as an item in the list of buttons; I guess that the current layout - not configurable- wastes room on the screen in many cases, and I would wish to get only the really indispensable separators… For 1.81 ?
scratch
marsh
