remove meta info in batch for several folders
yvonthirionet
Post by yvonthirionet »
Hi
Is it possible to remove meta info in batch for several folders in one action or did I do this action folder by folder ?
Thanks for answering..
Yvon
Re: remove meta info in batch for several folders
Perhaps you can use 'show files in subfolders', and use clean
oxygen2k
Post by oxygen2k »
I would also love to have some kind of option to batch remove metadata.
Why? Because i don't want to load/read all images in advance, because this can be a real pain if you have 20.000 or even 50.000 images. Maybe even with a progress bar?
So far, i've been using "JPEG & PNG Stripper" to do the job (awesome tool btw).
Just my 2 cents.
Peter2
Post by Peter2 »
You could take a look at http://www.xnconvert.com/ - there are also meatdata-features.
Peter
